169
26
Hi Guys, Sorry it's been a while, but I would like to design a device for testing PC boards in dairy sheds I do a LOT of fault-finding in. Now I have most of it all sorted but the one thing I can't get through my thick skull, is how I'm going to power this tester (which will in turn power the board under test), it needs to have a solid 25.5VDC to the board and I was thinking batteries, but this thing needs to be reasonably portable, sure, the current draw from something like this won't be any more than about 200-300mA, to power the test solenoids. Sure, SLA batteries could be an option, but I've never heard of a battery that has any more than a 24VDC output. I was also thinking a switch-mode PSU inside the box (that I want to keep as small as possible, if I can) but then you'd have to have 230VAC to the box, which isn't intrinsically a problem, but it affects the portability of the thing. Any ideas?
Posts: 9,931 Likes: 34
Google up DC/DC converter. That is basically a switching power supply with a DC input (battery?) and then outputs DC at a different voltage. Like a laptop power supply.
Woah! , Hey thanks guys, it's been a while since I've worked with DC-DC converters, but it's given me something to think about though! Will let you folks know how I get on and post some pics of the finished (prototype) tester.
JoeTestingEngr, It's a shame that Marlin P Jones don't ship to NZ, because the first one you posted looks exactly like what I'm after. I've searched all the local places here and all they have is nothing I want, it's all like boost 5VDC to 12VDC, which is not really what I'm after.
Posts: 827 Likes: 1
I think you're good to go, Trumpy! http://www.ebay.com/itm/like/121623601859?chn=ps&dispItem=1I also found them at All Electronics and they ship overseas. Better still, just Google "XL6009 Module", and you'll find them all over creation. I just double checked mine and it has the older, LM2577 adjustable switcher, in it. The XL6009 switches at 400kHz, instead of 50kHz. You'll probably be able to get yours from where MPJA buys theirs. Just add a heat sink if you start pushing 10W, or if it feels hot to the touch. Joe
Posts: 827 Likes: 1
TWH, The specific item that you linked to is a buck converter. Trumpy is looking for a boost converter. The good thing is that they're available on Ebay, Amazon, and many other sites. I was a little surprised to learn than I could buy 2 for $6.94, with Amazon Prime, and have them on Thursday. I just hope that I never get to the point of impulse buying switching regulators. Joe
Joe, You are awesome, mate. I managed to find a place called Surplustronics here that stock these modules, for the paltry sum of NZ$5.50 + freight. Thanks so much for your help.
