Electricians revenge
1 members (Scott35), 40 guests, and 14 robots.
Scott35 Online Happy OP
Per the Thread:
Walk In Cooler located at the General Discussion Area, the following PDF Plot Files are available for review...
  1. Sheet "E-3.0"; Refrigeration Equipment Power Plan (embedded in this post),
  2. Sheet "E-5.0"; Refrigeration Equipment Controls Plan (embedded in this post),
  3. Sheet "E-6.0"; Refrigeration Equipment Electrical Detail Drawings (embedded in following reply post).
These Drawings are PDF "Printed / Plotted Versions" of the AutoCAD Drawings, not the typical Graphical Image Files we normally use here; i.e.: .JPG, .PNG, .GIF, and similar.
Your Machine (Computer) will need an appropriate Utility or Plug-In, which is capable of opening (executing) and displaying Portable Document Format (PDF) Files. The most commonly used Utility is the Adobe Acrobat Reader Application, which may be Downloaded to Your Machine for free.
Check http://get.adobe.com/reader/otherversions/ for a compatible Reader Version.
Per the Attachments:
If no Graphics are displayed, Right-Click on the Link and select "Open In New Tab" from the drop-down list.
I am unsure if performing a "Normal" Left-Click on the Link Text will open the PDF Drawing + PDF Utility in a new Tab, so after posting this message, I will do a Smoke Test to see what happens.
If (when) everything works properly, I will revise this message post - adding descriptions and explanations per the Attached Plan Set Sheets.
Let's see if anything works properly!!! wink dunno
-- Scott
****** UPDATE ******
List of Drawing Sheets, with hyperlinks to the corresponding Posted Reply Message in this Thread:
Post #2: Elect. Details; Sheet E-6.0
Post #5: Plan Set Cover Page; Sheet E-1.0
Post #5: Building Footprint; Sheet E-1.1
Post #6: Ltg Compliance Forms; Sheet E-1.2
Post #7: Single Line Diagrams; Sheet E-2.0
Post #7: Panel Schedules; Sheet E-2.1
Post #8: Lighting Plan; Sheet E-4.0
Post #8: Lighting Layout Dimensions Plan; Sheet E-4.1
rev. 06-10-2011 22:38:00 S.E.T.
Attached PDF document
Well, everything seems to be working correctly so far... clap
To view Drawing in SAME WINDOW, Left-Click on the Link, select " "Open With" | Adobe Acrobat X.X | ", then select the "OK" Button. (*1)
To view Drawing in a NEW TAB, Right-Click on the Link, select " "Open With" | Adobe Acrobat X.X | ", then select the "OK" Button. (*1)
(*1)
If your PDF Utility is other than Adobe Acrobat, select the appropriate Application in the "Open With" Drop-Down Box.
Below is the Link for the remaining Electrical Plan Set Sheet "E-6.0"; Refrigeration Equipment Electrical Detail Drawings.
Will post an additional reply message in this Thread, which will contain descriptions and etc.
-- Scott
Scott:
Nice details!!! BTW, nice mods to the title/description block!!! That includes the company logo!
John;
Glad you liked the Plan Sheets - and the Company Logo!!!
-- Scott
All;
The remaining Plan Set Sheets for the "Larry, Moe and Curley Cold Storage Facility" are available for your review and use.
These remaining Sheets are spanned across (4) separate Reply Messages in this Thread (Replies following this Message).
These Plan Sheets will also be used with the existing Discussion Thread:
Design and Installation Discussions
At the Electrical Theory and Applications area.
Sheet List -
Sheet: "E-1.0" Electrical Set Cover Page.
Found On: Post #5
Sheet: "E-1.1" Building Footprint and Scope of Work Area.
Found On: Post #5
Sheet: "E-1.2" Interior Lighting Compliance Forms, Lighting Control Schematics Page.
Found On: Post #6
Sheet: "E-2.0" Single Line Diagram(s) Page.
Found On: Post #7
Sheet: "E-2.1" Panelboard Schedules Page.
Found On: Post #7
Sheet: "E-3.0" Electrical Power Plan.
Found On: Post #1 (previously uploaded and attached)
Sheet: "E-4.0" Interior Lighting Plan.
Found On: Post #8
Sheet: "E-4.1" Interior Lighting Layout (Dimensions) Plan.
Found On: Post #8
Sheet: "E-5.0" Refrigeration Controls Plan.
Sheet: "E-6.0" Electrical Detail Drawings.
Found On: Post #2 (previously uploaded and attached).
If there are any questions, comments, suggestions, or if there is something that needs clarification, feel free to post a message in one of the running Discussion Threads:
Design and Installation Discussions Thread
Walk In Cooler Thread
or one of the following options:
  • Create a new Discussion Thread (Post a Message) in the Electrical Theory and Discussions Area,
  • Create a new Discussion Thread (Post a Message) in the General Discussion Area,
  • Contact me via Private Message ("PM"),
  • Send me an E-mail Message.
Have fun everyone!!!
-- Scott
Remaining Plan Sheets to follow this Message.
06-10-2011 16:59:00 S.E.T.
POST #5
Project:
Larry, Moe and Curley Cold Storage - Triplestooge Distribution Center
This Post Contains The Following Plan Sheets:
E-1.0: Electrical Set Cover Page,
E-1.1: Building Footprint and Scope of Work Area.
-- Scott
POST #6
Project:
This Post Contains The Following Plan Sheet:
E-1.2: Interior Lighting Compliance Forms, Lighting Control Schematics.
-- Scott
POST #7
Project:
E-2.0: Single Line Diagram(s) Page,
E-2.1: Panelboard Schedules Page.
-- Scott
POST #8
Project:
E-4.0: Interior Lighting Plan,
E-4.1: Interior Lighting Layout (Dimensions) Plan.
--- END OF ATTACHED PLAN SHEET POSTS FOR THE LMC TRIPLESTOOGE PROJECT ---
-- Scott
