Electricians revenge
1 members (Scott35), 170 guests, and 12 robots.
CDS Offline
I noticed the 2001 is for up to 300 volts , the 2005 is good to 600 volts
The 2005 will find opens with power off .
Anyone see more difference than that .
I'd love to have one of these , but I can more afford the 2001 .
For residential , can anyone see the need to get the 2005 over the 2001 ?
CDS #192139 01/29/10 01:01 AM
I have the 2001. Ithas worked well most of the time. I have experiances the stray signal Reno spoke of many times. Noise also is a problem. I have had some older commercial building that the grounding was not so good and there is a ton of noise almost cannot hear the tone. I have not had good luck with dealing with Amprobe, as none of the local parts dealer carries them any longer, it has been troublesome to get leads that are damaged. The 2001 kit I purchased did not come with a tone generator. I had to buy that separate. It is a great asset. It is a great product, just not thrilled with Amprobe at this point.
