25
11
Posts: 3,682 Likes: 3
Administrator Member
And you stayed for how long?? and you slept? Did you have any nightmares about bad wiring? I probably would have.
Is that 4" round box cut-out to fit the 2x4?
Violation is 110.3 (B)
Looks more like the 2x4s are notched to accept the box.
napervillesoundtech: a week, Yes with a fire extinguisher and 911 on speed dail, yes it was a scene from the new movie snakes on a plane but the snakes were NMD 90 arking at the end, still have them from two weekes ago
ShockMe77: thank god no 2X4 cut around the box
if some one hands you lemons use the juice to blind them
very good SteveFehr i was too slow but you are correct
Posts: 7,383 Likes: 7
Ok, the guys with the really good memory....when was NM-B (Blue) around??
Wasn't the jacket color (blue) to signify that it was a 'new and improved' NM??
Darn, how soon we forget!
Well apparlenty soon in ontario it will identify bed room lines as bed rooms now must be protected by a gfi, but as for when it came around ???
I've seen it on the late 70s/early 80s.
The local hardware has the new blue stuff now.
Judging by the stack of tapes, it could the of the 1970s type.
Oh. Even better. It's those cheap plastic versions of the ceiling lampholder fixtures instead of the good porcelaine type.
I've seen them when they - literally - burn out. Not pretty.
That white melamine plastic doesn't hold up to heat from a bulb very well, first it goes yellow, starts splitting, and eventually it carbonizes and crumbles away.
Shinnston, WV USA
