1 members (Scott35), 161 guests, and 30 robots.
#190882 12/09/09 10:44 PM
Gentlemen:
Anyone have any dealings with induction lighting?
Sure sounds like a 'green' item to me.
POCO here is installing all new street lighting in township. All cobra heads being replaced with nice 150 watt induction luminaires, even powder coated in light green.
I've installed a few such -expensive- lights in areas that were hard to access for maintenance. That's the real plus: almost nothing to wear out over time.
Reno:
Yes, life expectancy is way up there. Any opinion on the quality of light?
Was your client happy?
Ballpark, how expensive was the luminaire?
Luminaires were about $4K ... had to be exp prf .... looks just like a MH light ... engineer spec'd, tiny part of job ( was building CNG fueling facility)
F
I have used in France with very hard to reach and tunnel luminaire both work very well as I expected and they can come on pretty fast but just a breif warm up once it stay on it look pretty good the colour itself is simuair to 41K MH's
The bulb life yeah I am aware it can go 100,000 hours before burn out but the question is the ballast I heard rumors some only last 50K hours but not confirmed.
Merci,Marc
If you're paying your maintenance techs several hundred dollars an hour and use a crew of 2 or 3 guys on every job, they're worth looking into.
I've never seen them installed anywhere where they ended up being less expensive in the long run.
Ghost307
Induction is fantastic light solution.
Induction operates at 1/2 of the wattage of HID, lasts up to 100,000 hours and has 80+ CRI light. I like to think of LED quality light at 1/4 of the costs.
We are a manufactures rep and picked up the product line once we had some fantastic success on a couple of jobs.
Check out the video the local news did on one of our jobs. WCPO ch. 9 news
Unless you've been running thousands of the units for 22+ years, you can't say with any certainty that these things will pass the test of time. We'll see.
There are tests run to capture performance over time they are the LM 79 & LM 80.
So there are test and data to back up the claims.
Joe
Here is a link to understanding the tests LM 79 & 80
http://apps1.eere.energy.gov/buildings/publications/pdfs/ssl/lightfair8_richman-ies.pdf
From Page 15 of the pdf
"LM-80 provides no determination or estimation of expected life or lumen output beyond test data."
